Old 09-18-2006, 10:42 PM
Carnut427 Carnut427 is offline
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
Originally Posted by mobilenuke
I thought you had to turn the oilpump shaft counterclockwise?
Mobilenuke is right; by spinning the oil pump clockwise, you had no oil in the engine galleries, bearings, oil filter, etc. and still may not. Pull the distributor and spin the oil pump counterclockwise. You should feel substantial pressure using a 1/2" drill. Can't say how your bearings are...
Best of luck,
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
