Old 09-21-2006, 06:44 AM
HSSS427's Avatar
HSSS427 HSSS427 is offline
Cobra Make, Engine: ERA #414 427 s/o w. Shelby Aluminum heads, Edelbrock Performer RPM Intake, Mighty Demon 750, Tremec TKO 600
Paul,
I have the plate and when I get a chance will try to post a pic for you. The one I have has a lip around the hole that the input shaft and bearing retainer stick through which indexes on the round opening in the bellhousing. As such, it aligns the plate opening with the bellhouse opening and it doesn't just rely on the bolts for alignment, but obviously it all has to line up or you can't bolt it together.
The spacer I have was on the car when I got it, so don't know where it came from. I did see adapters in a McLeod catalog online - you may want to search for "adapter plate" on the McLeod site.
