Thread: Blue smoke
  #22 (permalink)
Old 09-21-2006, 06:53 AM
HSSS427's Avatar
HSSS427 HSSS427 is offline
Cobra Make, Engine: ERA #414 427 s/o w. Shelby Aluminum heads, Edelbrock Performer RPM Intake, Mighty Demon 750, Tremec TKO 600
On the dip stick, it kind of depends on how it's mounted and installed. Generally the orientation of the stick shouldn't matter - what's important is that it's seated all the way down in the tube, and it was set-up to measure accurately at that point. If you're overfilling, the oil level could be high enought where the crank will start "frothing" up your oil. Typically a windage tray in the pan helps prevent that, but if the oil level is above the tray it doesn't help much. If it's reading too low, then obviously a different problem.
