Old 09-24-2006, 10:26 PM
Carnut427 Carnut427 is offline
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
Theoretically yes, but I wouldn't. Ford put the PCV in the valve cover around '65. You can certainly try it; it'll smoke (burn oil) from the oil getting to the PCV valve and/or there'll be oil leakage if there's a problem. If it doesn't smoke and no oil leakage around the PCV valve you're OK. Otherwise move the PCV to the valve cover, and always use a baffle.
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
