Old 09-26-2006, 04:38 AM
Gav's Avatar
Gav Gav is offline
Hogster,
Sorry for the delay but I had a bit of trouble getting in touch with the owner.
The system is a gas research twin gas carb arangement that has only done around 200hrs work.
One carb is a 400cfm unit and the secondry is 440cfm.
They are made to suit a spread bore manifold. The owner has everything, an 'end fill' 90ltr useable tank, 300mm round and 1500 long. It may not fit as it was made to fit behind the boats rear seat. The tachometric switch for the ignition and gas saftey shut off valves for tank and engine bay. The converter and all linkages and hoses. He also has extra jets and gas detection switchs that where in the bilge. you might want them for in the boot, or probably the bin.
Anyway he wants $1900 for the lot.
Give me a ring on 0407 110 641 if you are still keen.
