Old 09-27-2006, 05:37 AM
392cobra's Avatar
392cobra 392cobra is offline
6th Generation Texan
Originally Posted by Ze Colonel
I found that the attachment points for the lower bars are not square with the center line of the frame by 1/4 inch which equates to 0.34 degrees for my application. Based on this I need to have the drivers side lower link 1/4 inch ( out of 12 inch nominal) then the passenger side to get the rear end square up with the frame for zero thrust angle.
Not a huge amount but a little larger then I expected. I hope I do not encounter binding of the links with this much offset.
Anyone have experience with such matters?
Interesting about the 1/4".
Your's is the 4th LSC I know of with this difference.Found it on mine first.
I forget now if the lower left link length ended up longer or shorter.
No big deal,just get it square.
After you have everything finished up,( axle square,pinion angle),and take it out for a drive there is one final adjustment you might need.If the rearend wants to go left with spinning the tires ,add 1/8-1/4 turn of preload to the upper right bar.Take preload out if it wants to go right.
