  #35 (permalink)
Old 09-28-2006, 07:22 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by Zoom This
Well, I'll tell ya what. If I had to do it over again I'd opt for the top loader and get a 3.27 rear end ratio for my Superformance. My original Tremec 3550stuck into 4th gear 50 miles from home last year. I got rid of it and installed a TKO-600. With so much talk about sticking gears in the Tremec I'm dreading the day mines gets stuck. Then I will indeed get a top loader.
The tremec is a good tranny, but, my opinion is that it was designed for small block mustangs i.e. smaller engines with heavier weight than compared to a cobra. The 3550 is a super wide ratio 4 speed with an over drive, and the TKO600 is a wide ratio 4 speed, comparable to a wide ratio toploader, but with an overdrive as well. With the 2.78 1st gear of a wide ratio toploader, you can run 3.07 or 2.88 rears, and not really need an overdrive. The TKO600 has I believe a 2.87 first, even steeper than a wide ratio toploader, with 4th gear 1:1. With such a low 1st gear, I think the 3.07 or 2.88 rears are really optimal, and therefore negate the need for an overdrive. Assuming a toploader is more durable, I'd think you'd be better off to get a wide ratio TL with 3.07 or 2.88 rears than any of the tremecs. If you really want a CLOSE RATIO 5 SPEED, then the tremecs are not for you. You need to get either a richmond 5 speed, or a custom jerico or G-Force, of which all have 5th gear 1:1, with a steep 1st gear, so you would still run basically 3.07 or 2.88 rears.
The close ratio toploader with a 2.32 first will make it hard to get a good cruising rpm, yet still have good 1st gear power. I'm actually in the process of changing my wide ratio toploader to a close ratio, keeping the 3.07 rears. We'll see how it is, and if 1st is too high, maybe I'll switch in a richmond 5 speed with a 3.04 first. I would still have another application for the CL toploader. I thought the gear splits in the wide ratio toploader were a little too wide for my taste, and thought I'd be better off with a close ratio. We'll see.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
