Old 09-29-2006, 01:11 PM
kmarccoco kmarccoco is offline
Cobra Make, Engine: ERA
[quote=Jac Mac]:
Write your firing order down like this;( Lucky FE's all have same firing order)
1 5 4 2
6 3 7 8
Now when the valves on #6 cyl are 'rocking' ( ex closing/ in opening ) set the lash on # 1 valves, turn crank 1/4 turn clockwise and set #5 (#3 rocking), and so on. When you get finished on #2 the next set of 'Rocking' valves will be #1 to set #6. Use a marker pen to check off each valve after you have set it, when you have 16 marked valves your done!
when you say "now when the valves on #6 cyl are rocking", do you mean the cyl 6 in your diagram or the actual cyl number six?
