Thread: Fuel Pump
Old 10-01-2006, 06:09 PM
computerworks's Avatar
computerworks computerworks is offline
Original S/Cs (and Comp cars) used a mechanical fuel pump with the standard separate Ford canister filter up by the distributor, not mounted on the pump. It was supplemented by two electrical pumps in the trunk that were used as a 'reserve' and controlled by a dash-mounted switch.
The line from the trunk-mounted pumps met at a tee-fitting on the mechanical pump.
