Old 10-03-2006, 06:38 AM
Morris Morris is offline
Cobra Make, Engine: Kirkham #259
Ant
You are right on the mark...... however...the Cobra doesn't have much room for a heat exchanger in the bottom radiator hose.....
Just not much room for anything....
Also the heat exchanger will only get the oil up to the water temp on a cool day...... which is not hot enough..... needs to be 210*-220*.....
Heat exchanger will maintain oil temp up to water temp on cool days....
On Hot days ....no problem....with getting heat...in the oil.....
Morris
Morris
