Old 10-04-2006, 06:06 AM
AgShelby AgShelby is offline
Cobra Make, Engine: Hunter
Default Assistance
Originally Posted by slithering
You need to find the source of the draw. The constant replenishing of the battery is damaging you alternator, battery and any electronics. If you can't find it, PM me and I'll walk you through it.
Chris
Thanks very much for the offer. I am going to check the grounds this evening and will send you a note afterwards. All grounds are attached directly to the frame, which is powdercoated. This charging problem is intermittent, so a loose/improper ground could be the cause.
