Old 10-04-2006, 06:25 AM
sharpe 1's Avatar
sharpe 1 sharpe 1 is offline
Cobra Make, Engine: Midstates,SBF 357
It sounds like you may have a leaking diode in the alternator. You can check this buy turning everything off and then take a voltage reading from the alt.case to ground.If you get a voltage reading, you have a bad diode in the alt. It will leak voltage to ground and drain the bat.
sharpe 1
