Old 10-05-2006, 05:55 AM
Naumoff's Avatar
Naumoff Naumoff is offline
Cobra Make, Engine: Unique 427 S/C 427 FE S.O. 484 cu in
Originally Posted by 427SnakeSC
It all depends on what your final drive ratio is.
And what engine you are using.
Cruising at 65MPH at 3000rpm is fine for me.
For most with a 4 speed I think a 3.31 and a wide ratio would be a better street trans.
The Close ratio in a parking lot you are on and off the clutch pedal as the 1st gear speed is pretty fast but I can live with it as the acceleration from a stop light is incredible. Long legs and they go all the way up.
I took the car to the 1/4 mile drag strip and made a few passes I was at the traps in 3rd gear at 6000rpm. I shifted but could of finished the 1/4mile in third gear as the engine was still pulling.
Not that this is a drag car.
