Old 10-05-2006, 10:50 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Kieth
Change the needle seat assy on the seconaries of that carb
when a holley runs over the vent tubes with the engine not running and the throttle blades closed, it will run out around the throttle shafts
Check your fuel system for debries that is fouling your pressure regulator and needle seat assy
Flush all the hoses in the system, check all screens, set the regulator at 5-6 #, make sure your pump is shutting off
Jerry
