Old 10-05-2006, 01:06 PM
SuperHart's Avatar
SuperHart SuperHart is offline
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
OK, here's mine. I figured I couldn't let you guys have all the fun. I cut mine from a sheet of .125 aluminum after making a template. You will have to carefully countersink the holes for the screws that also mount the windshield. You will need slightly longer screws but do be careful that the screws are not too long or you could break your windshield. Of note is the fact that on the passenger side I had to end up bending the mounting bracket around 30* in order to get the mirror angled correctly so I could sight down the passenger side of the car. See the photos below.
DRIVER'S SIDE
PASSENGER SIDE
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
