Thread: Milky oil...
Old 10-08-2006, 07:22 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by Mike Bartlett
I'll get the head pressure tested and checked for straightness. If nothing turns up their I'll get the intake manifold checked the same way. If that passes then I guess I will reassemble then perform a leak down test to see if there is something going on with the block itself.
Any other ideas????
If, after reassembly, it still is leaking, have somebody do a pressure test of the completed engine, and then look through the distributor hole with a bore (fiberoptic) scope to see if you can spot the coolant leak.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
