Old 10-09-2006, 12:06 AM
Yetiman's Avatar
Yetiman Yetiman is offline
Cobra Make, Engine: Arntz/SBC/Jag
My Arntz is fitted with floor mounted pedals with the masters under the floor.
The assembly is mounted in a way so that the whole pedal assembly can be slid front to back to adjust for drivers of different leg lengths.
There is a removable aluminum plate for the floor which makes adjustment and bleeding very easy.
The car originally had all Hurst/Airhart masters with built in resevoirs, but I have swapped the clutch master for a Tilton using a remote mounted resevoir.
We come into this world naked, screaming, and covered in blood. With dedication and a little planning, you can go out the same way.
View my overflow Gallery (much more to come !)
