10-09-2006, 10:36 AM
CA
Cobra Make, Engine: SPF1715, Roush Built 434 ci Stroker, Dart Block, Ported AFR 205 Heads... 561 hp / 547 tq, Former Roush Show Car, Completed and Prepped By Olthoff Racing.
I thought about that but you can definitely feel that the car is not pulling like it should through the gears. I can go through the gears all the way into 5th and still keep it on the limiter at about 4800 and the car just feels slugish at only about 120 mph. It is definitely a real problem because you can feel it and the mph are off from what it should be in each gear if it was actually reving to 6200. It's almost like the limiter kicks in and does not shut off when you shift to the next gear (gears)...
