Old 10-09-2006, 11:59 AM
madmaxx madmaxx is offline
Anything that came from VCM or Keith Craft of Plano is/was plagued with issues:
1) no oil dipsitck and jerry rigged oil pump pick up. Car would have been out of oil when a quart low!!!!!!
2) horrible exhaust leak between header and side pipe - someone actually tack welded it to prevent from rattling
3) Wire harness run poorly, conduit melted
4) emergency brake never adjusted.
5) wrong gear in transmission for speedohmeter
6)speedohmeter cable broke at 150 miles do to sharp bend the way cable was run.
7) Headlight dimmer switch failed
8) vacuum port on carburator plugged with a piece of tape which leaked
9) the use of all thread to hold the water pump on, looked like sheet
10) multiple wiring connector failures on MSD unit, you think they could have used the correct size butt connectors.
11) fuel gage never calibrated correctly
12) fuel pump would lose prime and no fuel filter installed
i can go on but why
