Old 10-11-2006, 05:56 AM
mj_duell mj_duell is offline
Send a message via AIM to mj_duell
Originally Posted by silverback
We use nascar style sway bars from speedway engineering in california on all of our race cars. our set ups on the roadsters as well as the daytonas are tubular upper and lower control arms coil overs and various brake set ups. we use speedways arms and straight bars and use various size link bars with hiem joints that allow pre loading if need be. The set ups work great and are very easy to adjust. Im not a salesperson for speedway , but check out there web site.
We use and have a modified Speedway bar set too. There is no problem running sway bars with coil-overs if you have a properly tuned suspension setup. Call Speedway and tell them about the car you want to add the bars too. They will ask you specific questions about your set up and recommend the right bars to use.
--Mike / Turn Ten Racing, Inc.
