Old 10-11-2006, 10:34 PM
Andrew Teal Andrew Teal is offline
Cobra Make, Engine: Classic ND 427 big block 427 ford with tri power I know the 427 didnt come with tri power just wanted something different. 9 inc. ford rear end top loader four wheel dic brakes.
Ron,
I have a 427 in my Cobra and used the same set up as Anthony posting. I due have a one inch. spacer with stock casket on each side. I had to cut some holes in my turkey pan bottom so the carb linkeage would move with out hitting the pan bottom. I also had heat treating done to the pan. The same stuff they put on header pipes. I got the pan at Finish line Inc wwwfinishlineaccessories.com There was no problems with distributor clearing. I have had no vac. leaks. I have a friend who has a new one that he didnt use, he may want to part with it? Its for a 351 ford. Let me know.
Andy
