Old 10-13-2006, 05:01 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
The valve is part of the pump. There is a cotter pin or bolt that retains the pressure spring. The old days trick was to shim the plate or plug the bolt or cotter pin held back with a washer to increase the pump pressure.
That pump pressure you are posting is good. I agree with the statement you probably have your clearances a bit closer.
