Old 10-15-2006, 06:11 AM
LoBelly's Avatar
LoBelly LoBelly is offline
Default Extinct Manifold?
All,
'Old Smokey' is the name recently aquired by my 289w. It (the engine) came with the kit I picked up and after sitting for 15+ years (1990 kit) my brother/mechanic managed to revive it.
Have been having a bit of fun during the build however we suspect that the big sit has caused some issues (lots of blow by, a bit smokey and a stream of greeen fluid under the car) and while I quite like its willingness - albeit limited to 5000rpm - I expect that its just a matter of time before something ventilates the crank case.
I expect that this event will occur while still impoverished by the build cost for the car, and that I will consequently have to but the 'wanna have' engine on hold and put together a stop gap.
Naturally I'm looking to get as much bang for my buck as I can and will want to reuse parts that I already have.
Toward that end I'm trying to figure out if the manifold I have is worth hanging on to.
Its a Holley Street Dominator single plane.
When I look at the Holley catalogue it only talks about these in the past tense and only in the context of SBChev where they say it was good for 0-6000rpm.
I'm suspicious that if they aren't making them anymore there's a reason for that and its not looking good for re-use. But does anybody know?
And, if you do - will it feed a 302/347?
Any other info would be appreciated
ta
LoBelly
