Old 10-16-2006, 03:35 PM
xlr8or's Avatar
xlr8or xlr8or is offline
Yes I can tell you from personal experience it's been done and a 385 series engine fits without any permanent modifications to the car. You do need to lift the engine about an inch for bellhousing clearance and build custom headers. Hood clearance is an issue. You also have clearance issues around the headers and the steering shaft. You are limited on clearance in the front since the 385 is longer than an FE. If you would like to set the engine down and to the rear you will need to notch the frame rails for the bellhousing and build some custom motor mounts.
Are you looking to buy a Kirkham?
