Old 10-17-2006, 02:34 PM
jimmymac jimmymac is offline
Default Headers??????????
I have a set of Hooker Super Comp 2 1/8 on my 67 Mustang on a 427 stroker motor. Coated at Jet hot got just under a grand in them. Fit tight but you wont need the big ones 1 3/4 or 2 inch should be fine. the smaller tube on lower performance engines give more low end power. Before you coat them cut about a 1/4 to 3/8 inch from the flange between the tubes Installation will be eased. I lowered my uppercontrol arms so the car sit low. I have 28 inch tires on the front!!! Super comps set 3 inches below my Cobra t -pan I have 2 1/2 ground clearance. Smaller dia. tubes my have more ground clearance? The leading edge of my front bumper is 19 1/2 form floor for your comparisons. Add to my 2 1/2 clearance for every inch your bumper sit higher than mine for your clearance. I wouldn't change a thing.the car handles perfect. Steers left and right in a four wheel drift. If a Cobra handles that good I got to get one! Oh weld some skid plates on the lowest parts of the tubes If you don't have 4 inches clearance an keep good shocks on it! Do a good port job on Edelbrock heads,.no regrets heh! Also have a custom cam cut for your car it cost no more. Bullet cams ask for John Partrige Go get em jimmymac
