Home Depot carries aluminum strips in the floor covering department designed to cover the seam between two carpets. The strips are 1" wide. I bought two strips, bent them into shape using the propane tank from my grille as a buck, cut them to proper length and secured each strip with #6x1/4" stainless sheet metal screws. They are a cinch to keep shiny with an occasional rub with 4-0 steel wool. Total cost, less then $3.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
