Old 10-20-2006, 06:34 AM
khansmith's Avatar
khansmith khansmith is offline
Cobra Make, Engine: Hurricane Motorsports, Southern Automotive 428 FE
Originally Posted by Clois Harlan
Kahn,
I know that many people don't think you need to run a ground from your frame to your engine but I have found that if you do, you will eliminate a lot of minor voltage problems later on. Take an 18" piece of battery cable and attach it to an unpainted spot on your block and then GRIND off the paint in an adjacent area of your frame and attach it (you can buy a 0 to 4 gauge battery cable with eyelet connectors on both ends that will accept a 5/16" bolt). You may need to drill a hole in your frame and tap it for a 5/16" bolt.
Sometimes after your car has been on the road a short while your grounds will loose their effectiveness because of dirt or road debris and your car will become harder to start or your headlights will become dim. Real easy thing to do at this stage of your build.
Clois
Thanks Clois
I was checking out the block last night and there are lots of different areas on the block I coudl attach the negative to. Where on your block did you choose to attach?
Hurricane Motorsports: HM1046
Follow the build on my blog: http://khansmith.blogspot.com/
1974 Pantera resurrection blog:http://1974pantera.blogspot.com/
