Old 10-21-2006, 08:31 AM
donzi 1 donzi 1 is offline
Default Serpintine setup water pump required
I have a question regarding serpentine belt setup for a SB ford (1986 302). I would like to run a serpentine belt using only the crank, alternator and water pump. Trying to locate a standard rotation water pump c/w the proper ribbed pulley is very difficult as all the local parts supplier require an original application. Any suggestion or direction would be of help.
Thanks Brad
