Old 10-21-2006, 05:23 PM
Rick Parker's Avatar
Typically the holes drilled as OEM or added later are intended to eliminate the need of opening the secondaries and ultimately exposing the slot creating an overly rich mixture in an attempt to gain a good idle. Usually with very high duration and overlap cams. (low manifold vacuum)
Rick
