Old 10-22-2006, 07:13 PM
JayBar's Avatar
JayBar JayBar is offline
Cobra Make, Engine: BDR#078,408 Dart Block, TKO 600,Indigo Blue, White Stripe
Send a message via Yahoo to JayBar
I had the same problem. Reg fixed it. I believe they drill out the borken bolt, then drill out the hole also. They then installed a grade "8" (it think) nut and bolt. What ever the grade of the replacement is is stronger than stock and now that it is not threaded into the housing if it brakes the replacement is much easier.
JayB
Jupiter, FL
