Old 10-23-2006, 06:15 AM
neverwouldof neverwouldof is offline
Cobra Make, Engine: Contemporary CCX-34201
Default Contemporary Cobra up for Sale and ready for Racing (freds cobra)
http://pg.photos.yahoo.com/ph/northf...ltor/my_photos
Above is Link to Pictures...
Big Block Contemporary Cobra, built with the best parts available at the factory! Look at all the premium brands for sale and most cars dont have half the value in parts/construction to them as this one does. A ton of money was spent on the construction of this car! The brake system alone would cost about 9K to buy. You couldnt build this car for $90K.
1997 Contemporary 427
Last Factory Assembled Contemporary Cobra 427
Titled as 1966 Ford Convertible
5900 Miles
2,650 lbs/wet w/9 gal gas
Body
Cobalt Blue Pearl Deltron Basecoat/Clearcoat Urethane Paint
White Le Mans Stripes
Red Team Fender Stripes
Chrome Quik Jacks
Aluminum Oil Cooler Shroud
Aluminum Nose Shroud
Aluminum Engine Compartment
Aluminum Hood Liner
Aluminum Hood Scoop - (Functional) Installed with stainless button head machine screws
Chrome Roll Bar
Drivers side mirror (have another NIB for passenger side)
Wind WIngs/Sunvisors
White Side Pipes Airborne Ceramic Coated - Special high performance low backpressure resonator design not glass paks)
Leather Seats
Carroll Shelby Gauges ( Have some Smiths Gauges to go with car)
Wilwood Brake Proportioning Valve
Chromed hinges and latches
Howe NASCAR Aluminum Radiator
Puller Electric Fan
Front Dual Shelby Fans
Inside Of Passenger compartment lip finished underneath
Inside lips of Wheel Wells finished underneath
Custom lower dash bow ( to prevent flexing of dash)
*** Transmission tunnel fitted with custom internal steel shell liner to protect occupants in the event of a driveshaft failure.
Custom Pedal Assembly
CHASSIS
2nd Generation Contemporary round tube frame - This car has the steering rack factory installed with a reengineered geometry to completely eliminate all bump steer. Had Contemporary gone forward, this geometry would have been made standard.
Entire Frame/Suspension Powdercoated Black
Watts Link Rear Suspension System - Polished Aluminum
2.88 Salisbury independent rear center section (Trans has 1:1 5th gear no overdrive)
Coil Over Front End / Carrera Coil Over Shocks (6)
Delrin Suspension Bushings
Custom Billet Front Control Arms (E Jag geometry)
Billet Hubs/carriers
Jaguar Rack
Custom Rear Control Arms
Custom Rear Half Shafts
Triangle Engineering Custom Aluminum Foam Filled Fuel Cel
Billet "COBRA" Rear Tie Bar
PS Engineering Pin Drive 17" Wheels
BF Goodrich G Force Tires 335 rear 265 front
Stainless Steel Spinners/Knockoffs
Custom Alcon 4 Piston 14 inch rotors front 13 inch rotors inboard rear 90 Compound Pads
Auxiliary Emergency Brake
Original Ford Expansion Tank Restored w/ Black Basecoat/Clearcoat Urethane
CNC Billet Master Cylinder
Stef's Fabrication Radiator Overflow Tank
DRIVETRAIN
ENGINE
Assembled with ARP Fasteners
NOS 427 Sideoiler Block standard bore 4.233
Oil Gallery Restrictors Installed and Oiling System Blueprinted To Feed Lifter Galleries and Pump Oil Through Pushrods to top end. far superior to normal 427/FE System.
Relief Valve Shimmed to provide 60 PSI Oil pressure/idle
Block Honed, Line Bored, and trued/decked By Pat Musi Performance
10/10 428 CJ Crankshaft Internally Balanced and Micropolished
ESP Rods / ARP 8720 Rod Bolts
Diamond Racing Forged Pistons 10.25:1 Compression
Hoffman Machine H -13 Tool Steel Wristpins with dual circlips installed
Edelbrock MR Aluminum Heads Ported by Pat Musi Performance
Manley Severe Duty Stainless Valves 2.225/1.750
Crane Dual Valve Springs Retainers
Perfect Circle Teflon Valve Seals
Clevite Engine Bearings
Mellings High Volume Oil Pump
Heavy Duty Oil Pump Drive
Jeff Johnstone/ Billet Fabrication Custom Oil Pan and Windage Tray
Crane Solid Mechanical Roller Lifters
Crane R - 246 Mechanical Roller Cam 246/256 @.050 .580/.601 lift
Jesel Competition Pushrods
Jesel Custom Shaft Mount NASCAR Valvetrain
NOS Ford Flywheel
Edelbrock Aluminum Water Pump
MSD Billet Distributor
MSD 6A Ignition Control
McLeod High Torque Starter
Holley High Pressure Mechanical Fuel Pump
Black Powder Coated Fuel Rail
Original Ford Tunnel Wedge MR 427 Dual Quad Intake with pair of Original 735 Holley 4 BBl
Billet Remote Oil Fileter Mount/Braided Stainless hoses/AN Fittings throughout.
Aluminum Snorkel Breather
Pentroof 427 Valve Covers
Original 427 Harmonic Balancer
K&N Air Filters in Hellings Chrome Housings
Performance:Flywheel on Hoffman Dynomometer 603 HP @ 6700rpm /590 Ft Lbs on Race Fuel and at 4800rpm will stay at 180F all day long.
TRANSMISSION
Richmond 5 Speed (Shifts w/o clutch)
Long Shifter/Handle
Lakewood Blowproof Bellhousing (Powdercoated)
Hayes 11 Inch Clutch/Throwout Bearing
Hydraulic Slave Cylinder
PRICE: $59K
Serious Inquiries only, no tire kickers!
Investments have become available to me and i can't turn away... I planned on keeping this car for ever and that's why i bought the best setup i could find. But i have to jump on this deal so i can retire sooner then later!
email me at Northfloridarealtor@yahoo.com
Thanks for looking... Keith
