Earl,
P.V. in that drawing does refer to the point view - viewing a plane parallel to the ground.
However, it appears that someone had problems with that dimensioning and added numbers by hand to the drawing from the firewall, the back of the quarter panel, and the car's centerline to make it a bit easier to measure.
Just remember that even those handwriiten dimensions must be in a plane that is parallel to the ground not along the body which is not parallel to the ground. Use a long level and carpenters square to establish the initial points, and measure from there.
Cheers!
Dave
Dave
