Old 10-24-2006, 07:56 PM
RedCSX1's Avatar
RedCSX1 RedCSX1 is offline
Cobra Make, Engine: Shelby CSX 4766 (Vegas Built) with 482 Aluminum Pond motor
Originally Posted by Burgs
Red and Rick,
That cam is the same one Keith installed in my Pond 482 last February. I have put just under 500 miles on it this summer sorting things out. One of my requests when purchasing the motor was that I did NOT want to be dealing with those things under the valve covers! I was told at that time, that I would need to adjust, and re torque, the valve train initially, but should not have to mess with it after that. I need to check a few things with them in regards to this anyways, so I will ask about future needs again, to clarify.
Brad
Brad,
We have the same motor. This past month I had two lifter adjusters break. Some bent valves and push rods. Just trying to determine the cause and attempting to prevent the same thing from occurring. I am not placing blame on Keith. The adjusters themselves are suspect and will be replaced out with ones from T&D which are superior. The heads are now at Keith Craft for rebuild. He did not intially build up the edlebrock heads, this was done by Trans Am Racing in Gardena CA.
Morgan LeBlanc
Fresno CA
