Old 10-24-2006, 10:13 PM
Carnut427 Carnut427 is offline
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
Originally Posted by Anthony
I don't think that it's not because Ford didn't have the technology, but in the basic design of the engine. The "original" 427 had water jackets completely surrounding each cylinder, for even cooling. The Genesis has siamesed cylinders, that is no coolant pasing between the cylinders. If Ford wanted the 427 this way, I'm sure they could have cast it the same way as the Genesis. I'm not saying one way is better than the other.
You're right, Anthony. I used the wrong word. Substitute knowledge for technology. Ford (nor the other manufacturers) knew siamesed cylinders would work. To my knowledge, Chevy was the first to do it on the 400 smallblock. Another thought is how much metal must you have minimum around the siamesed bores for the process to work? Ford could have saved a lot of money by making the cylinder walls thicker. They scrapped a lot of 427 blocks because of core shift and the sand used for the casting was so thin between the bores it wouldn't always stay in place.
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
