Thread: Nuts and bolts
Old 10-25-2006, 02:04 PM
SuperHart's Avatar
SuperHart SuperHart is offline
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
I totally agree with Rick Parker. When I first built my roadster I used grade 8 1/2" bolts to secure the trailing arms of the rear suspension. I broke the upper front bolts twice and finally decided to use a grade 5 bolt because the grade 8s were so brittle. Three years later and I haven't broken a single grade 5 bolt. There is a world of difference between clamping power and shear strength. The higher the bolt grade, the higher the clamping strength but also the lower the shear strength.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
