Old 10-25-2006, 06:55 PM
Burnd's Avatar
Burnd Burnd is offline
Cobra Make, Engine: West Coast Cobra, 427SO 2x4's, 630HP/600TQ
Check the connection on the relay to the fuel pump and make sure it's not "jiggling". I had that problem under vibration and it would intermittly shut down. Any loose connection in the electrical sequence will do that too. Clogged fuel filter will give you the same perception in driving but not if you can hear the electric pump shutting down.
Secondly; what color is your ceramic? I use VHT OVER the ceramics on mine which includes headers, collectors and side pipes. My ceramic was egg shell white but I overcoated with 2 coats of a VHT Header paint in black followed by a VHT clear. Any spot damage during the driving season just gets a 5 second respray and it looks like new and blends right in. It's so easy and simple, I can't stand it. I think my ceramic is .018 thick and with a sand paper texture so there's no sheen. You're going to have to go some to damage the ceramic unless you chip it. If they are not VHT header paint coated, the color should come right through from the original ceramic coating process. The only damage I have done to mine was scraping the underside of the sidepipes on a lift, which I immediatly recoated with the VHT color stuff. You wouldn't know it was there unless I told you. Probably the biggest nuisance is getting the melted goo off the headers. I was told by my manufacturer; nothing liquid is going to hurt the ceramics so try an adhesive cutter of some nature and see if it rubs up like chewing gum. Ain't gonna hurt it.
"Shut up and take the pain".
