Old 10-26-2006, 05:39 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Dave is absolutely right. There are several alternatives to the Datsun/Toyota slave cylinder available. There is an old article in one of the Fast Ford Magazines that shows a step by step procedure of installing a slave cylinder on your Tremic (I believe it came out in the Spring of 2002). Article gives diminsions and pictures of how to properly install a slave cylinder on your TREMIC. One key point they made was to use a stop or limiter on your pedal to stop you from over extending your piston in your slave cyl.
Clois
"Let's roll"
"Be part of Something Good
