Old 10-26-2006, 12:52 PM
Burgs's Avatar
Burgs Burgs is offline
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
Originally Posted by LuvDaBlues
Thanks guys,
Kbisconti, The present configuration is a push type.
S.S.
The willwood slave would be flipped around so it pulls to the rear of the car. The heim joint end is attached to the frame rail with a spacer to get it close to lined up, and the threaded rod goes thru the fork and can move freely because of the heim at the other end of the slave. This slave also has 1 3/8" of travel.
