Old 10-27-2006, 11:36 AM
Burgs's Avatar
Burgs Burgs is offline
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
Morgan,
I spoke with Keith this AM, and discussed the valve train maintenance with this set-up. It is a good idea after a few hundred miles or so, not a must, but if you want to, you can retorque the intake, heads (not as critical), rocker studs and 1/2 turn preload on the lifters. Doing this on a cold engine is fine, and once you do this once at the beginning, and you will not need to do it again.
Brad
