Old 10-28-2006, 02:40 PM
Woodz428's Avatar
Woodz428 Woodz428 is offline
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
Originally Posted by 69 Mach I
If ordering a custom grind hydraulic roller, I know that Comp will press an iron gear on the cam in place of a steel one if you ask.
Is this a new procedure??? All the cams I've seen appear to be a single unit that is machined, how can they press a different gear on?? Some OEM cams are now made by pressing the lobes onto a hollow shaft, but I thought all the cams for most engines were cast/forged as a single piece.
WDZ
