Old 10-30-2006, 11:50 AM
Murphy's Avatar
Murphy Murphy is offline
Cobra Make, Engine: Kirkham #473 427 every option, Keithcraft aluminum FE 482 ci. Mass Flo FI. Tremec TKO 600.
Glen, I have to agree with Rick on the scattershield. Mine is cut on the bottom so it does not hang down.
I just called McLeod (tech line 714-630-2764) to confirm that the 14005-30 is the kit with a slip on (not bolt on) T.O. bearing and hyd. cyl. that fits Tremec trans (must have the Ford imput shaft) or any top-loader trans (except the somewhat rare race version 1 3/8" imput shaft one). The bearing slips on and will work if you have a minimum of 3" from the transmission face side of the scattershield to the highest tip of the spring fingers on your pressure plate. If the distance is less than 3" mine will not work. I suggest calling McLeod and describe your setup. Let me know and I can send you a picture. Mike Murphy
