Thread: Muncie box
Old 10-30-2006, 01:02 PM
bkozlow bkozlow is offline
Cobra Make, Engine: built the molds and body composite construction
Default Hurst shifter
The Hurst shifter is the classic H pattern with reverse up and to the left of first. I am willing to bet you have a standard Hurst 4-speed shifter that does not have the lockout for reverse as these are about double the price of the standard Hurst shifter. The numbers for the Hurst Super Speedway shifter, I gave you will work on the M-20 box with the correct linkage kit. All you need is the shifter part and the linkage rods which you can make if you want to save some money from aluminum rod and heim joints. Since you have a shifter all ready on the trans you can use those adapters. I am not sure about the leaving the speedo gear out but you will have to have some sort of a threaded cover or tight plastic cover to seal it up from dirt and water getting in.
Bill K
