Old 10-31-2006, 03:45 AM
Default Storage of a motor
Paul If your motor is not together, don't put it together. Put the short block in a double bag with moisture bags to keep out dampness. Go to the marine store and get a spray fogger kit and spray the whole motor down inside and out, seal the bags and put the engine off the floor or ground. I don't believe in leaving a motor on an engine stand for long periods. I have proof the the back cylinder come out of round from .001-.0022". The heads spray with oil or WD-40 and bag them too. Assembly the motor when you are ready for it. I fog my motor in the winter, run new oil and filter to operating temps and add a bottle of Lucas oil stablizer. Re move the rocker shafts, and plug the exhaust with moisture bags. Change plugs in the spring, reinstall the rocker shafts, but remove my lifters to drain the oil, anti pump lifters not drain back. Fire it up out side. I now have a 3 quart perluber accusump that I use befor startup. Works great. This works for me. I am not a fan of rotating the motor every month. Under the oil clings to the metal parts, you will get dry parts. I did the Lucas challenge in my tow truck and let the truck sit for 3 months. Without Lucas valve and motor noise for the first 10 seconds, then the motor was quiet. With the additive same test no noise on startup. I use 10-40w oil. Try it in your own car or truck and see what happens. Rick Lake
