  #21 (permalink)
Old 11-01-2006, 08:55 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
How well does it steer with the spindles turned around to make it rear steer in the 32?
With coil overs that short and at that much angle does you have to use higher rate springs?
The units I've worked on we use the longer coilover and the mounting angle the Corvette used.Of course the upper mounts then become critical and bracing takes some imagination!
Jerry
