Old 11-01-2006, 05:24 PM
MadDog MadDog is offline
Cobra Make, Engine: FFR Markll non doner build,Ford Racing 392,tremec TKO,8.8w/3;73s,Baer brakes,Black w/silver stripes,w/carbon fiber,gauges,spats,hood soop,door panel inserts.
Bob is correct. Remember that the cam drives the distributor that drives the oil pump. So if anything stops the pump or tries to slow it down it is supose to shear off the shear pin that holds the gear on the dist shaft but I have seen it break the gear and sometimes the gear on the cam before the shear pin.
I would recomend checking the oil pump and the cam gear.
MadDog
