Old 11-02-2006, 08:57 AM
Wayne Maybury's Avatar
Wayne Maybury Wayne Maybury is offline
Canadian Gashole
Cobra Make, Engine: Johnex 427 S/C, 351W, 472 HP, 444 lbs. torque
Default Question about shaft mounted rocker arms
This question is probably not really suited for the Cobra forum but maybe someone has the answer or possibly give me an idea where else to go to get the answer.
A friend runs a SBC 357 cu in "Dirt" modified race car. He has been using pedistal mounted rocker arms but wants to switch to a shaft mounted system. The cost is in the $2000 range so he wants to make sure he gets it right before ordering the kit.
He is using Brodix spec heads, "SP CH" is the designation. The question is how much offset is required? for the intakes? for the exhaust? Brodix says to use the same offset as for their Track 1 heads but the problem is that each rocker manufacturer indicates different offsets. Some say as much as .250" while other say no offset at all.
Does anyone know what offset to use? My friend is going to try to determine the amount of offset required by using a straight edge square and some micrometers but this will be a guess at best. It would be great to get the opinion from someone that has already run this setup.
Wayne
Don't get caught dead, sitting on your seat belt.
