Old 11-02-2006, 11:11 AM
Jimi G's Avatar
Jimi G Jimi G is offline
Pmfranke,
The lower the ratio # the lower your RPM's will be, higher # will be higher RPM's. As for the T5z, the gear howl in 4th and 5th more than likely is coming from your rearend, noices in the rear gear set will travel up your driveline to make you think it is coming from the tranny. As for it grinding going into 5th, I would first check the clearance between your throwout bearing and the fingers on your pressure plate, it should be between .100 and .300. If all is well there and you are getting adequate engagement movement then there is a good chance you have a worn sycro on 5th. jimig@standardtransmission.com
True friendship is like peeing your pants, everyone can see it, but only you can feel its warmth.
Plan your life like you will live to be 120 years old...Live your life like you could die tomorrow.
