Old 11-02-2006, 03:54 PM
Fordfan69 Fordfan69 is offline
Default clarification on clarification.
I would like to re-clarify things a bit:
1. The reason why I joined this forum was that I knew that many people with the Cobra cars a running the Tremec transmission and I wanted to let them know of the trouble I was having. Some might find it useful to know of problems with certain parts before the purchase them. I know I would want to know if I was planning on buying something and others were having problems/ breakage with them. It's my hard earned money that I am going to spend.
2. I fully agree that I did write that letter stating that I was going down the road. I wrote that letter because AFTER I received the transmission, I then read the warranty information that Keisler would not cover the trans if it was raced. I stated this before: they did not once say that when I mentioned upon ordering this tranny, that part of my intention was to take it to the track OCCASSIONALLY. I did race the car at the track and 3rd gear did break at the track. I had a strong feeling that had I been honest with them about that, They definitely would not warranty it. I also stated before that had they stopped me when I mentioned occassionally racing it, I would have rethought purchasing it and purchased a transmission more appropriate for me and my outings.
3. Every single knowledgealbe and even not-so knowledgeable people that I have shown the gears to absolutely said it must have been some sort of a part failure or improper installation (gear meshing not right). I am the first one to admit that I am in no way perfect, but I and others looked very hard and I also thought back to the moment very hard and there is not a doubt in my mind that I did not miss that shift. I've attached another picture showing more clearly 3rd gear's dog teeth and synchro blocker. They are in excellent shape. The shape of ones that came out of a box with only slightly more than 1000 miles on them. If I wasn't in the gear all the way or missed the shift, the dog teeth would be damaged and/or rounded. Not the case. If any damage would occur from improper usage, as they say, wouldn't it be to the dog teeth. How is it possible that they are mint. That tells me and others that the synchro hub was fully engaged to the 3rd gear. I am not saying that Keisler assembled the tranny incorrectly, but there is something wrong for the main teeth to fail in that way on that angle opposite that of the cluster gear.
4. Another reason why I felt this failure was not a failure of my own doing is due to the fact that I found another user of the Tremec 5speed that also had a failure. When I looked at his picture, It looked almost identical to mine. The teeth sheared off on the same angles and all. Another reason why I thought it might be a part failure. You can see his picture and read his post if you want at http://www.pro-touring.com/forum/showthread.php?t=23218
5. The offer that Keisler made to me was a little appauling. I spend nearly $3900. with them on the kit and clutch, and they want me to spend another $430. on the parts. They said they would reassemble it for free. When I called to find out the progress, I was told it was "dissassembled in 800 pieces on the bench" They sent it back to me fully assembled. They had to reassemble it anyway whether I chose to fix or not. So what were they really offering. Nothing. I just chose to not give them any more money and give it to someone else.
6. My post was highly accurate. The car was brought to the track once, didn't even make down the whole way , driven down the return road and into the pits onto a rented trailer. pushed off trailer and not driven again. period. (That's why the rest of the transmission looks as clean as it does.) If I would have driven it after like someone stated I probably did, do you think the transmission would look the way it does inside? No. it wouldn't.
Again, The only reason I made my experience public on these forums (only 3) is to alert other car people to what happened so they can make better informed decisions. That's all. I would hope others do the same.
Thanks,
Greg.
