Old 11-02-2006, 04:16 PM
JCoop's Avatar
JCoop JCoop is offline
Cobra Make, Engine: Superformance, FRP460 Big Block
Originally Posted by ByronRACE
Causes of blow-by:
-improper bore finish, rings don't seat during break in
-mixture too rich, rings don't seat during break in
-wrong ring package
-wrong piston to bore clearance
-rings installed wrong
-excessive ring end-gap
-detonation damage (rings, ring lands, pistons)
But what is "excessive" blow-by...are you sure it isn't normal? All engines have blow-by.
The car had 4 qts of oil when we picked it up. Upon changing the oil and filter, filling it to the full mark with 6.5 qts, the oil pressure was up at 65. It had one of these breather caps that had a hole on top, and foam inside. You could see the oil mist pulsating upwards from the hole. So we installed a regular Ford Racing breather cap with the little holes at the base of the cap. You could still see the oil mist pulsating outward from the base. the 460 on SPF#1052 has the same cap and no oil ever pulsates out of it.
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
