Old 11-04-2006, 06:35 AM
Default Air filter Assembly
Rich P That's a nice setup on your car. You have the same EFI throttle body as my 452 motor. The twm setup is going to be bigger and larger to work. I have a paxton hood so size is not a problem for me, but under the stock hood, clearance problem is going to be there. An air box to all the throttle bodies is not hard to make, but getting a good air flow to the rear bodies is going to be a problem. Air doesn't like to bend around corners. It also makes heat, not alot, but enough. This is why nascar sucks the air from the base of the cowl. Rick Lake
